跳转到主内容
Dell Precision M3800 Speaker Replacement
你所需要的
  1. Dell Precision M3800 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Speaker Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Speaker Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Dell Precision M3800 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Unplug the red, white, and blue speaker wire connected to the main motherboard.
  5. Dell Precision M3800 Speaker Replacement: 步骤 5 中的图像 1,2 Dell Precision M3800 Speaker Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 2 mm screws.
  6. Dell Precision M3800 Speaker Replacement: 步骤 6 中的图像 1,2 Dell Precision M3800 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the speakers by gently pulling up on the main unit on the left hand side. Make sure to not lose the rubber bushings that are attached to the sides of the speakers.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 11
总计 398
