跳转到主内容
Dell Precision M3800 Memory Module Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell Precision M3800 Memory Module Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 Memory Module Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Turn the system badge fap over and place it on the base cover.
    • Remove the screws that secure the base cover to the computer. Release and remove the base cover from the computer.
    • NOTE: To remove the screws from the base cover, use a T5 Torx screwdriver.
    • Lift up and remove the base cover from the computer.
  2. Dell Precision M3800 Memory Module Replacement, Battery: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  3. Dell Precision M3800 Memory Module Replacement, Memory Module: 步骤 3 中的图像 1,1
    • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
结论
Johnathan Hammond
于02/28/18注册
45,540 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,993篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 154
