跳转到主内容
Dell Precision M3800 Hard Drive Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Dell Precision M3800 Hard Drive Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 Hard Drive Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Turn the system badge fap over and place it on the base cover.
    • Remove the screws that secure the base cover to the computer. Release and remove the base cover from the computer.
    • NOTE: To remove the screws from the base cover, use a T5 Torx screwdriver.
    • Lift up and remove the base cover from the computer.
  2. Dell Precision M3800 Hard Drive Replacement, Battery: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  3. Dell Precision M3800 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Disconnect the hard-drive cable from the system board [1].
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard drive off the computer [2].
  4. Dell Precision M3800 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Disconnect the hard-drive cable from the hard drive [1].
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket [2].
结论
3等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
45,034 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
一条评论
Very helpful guide! Easy to follow and helped me complete this task with ease
Chris Stockton - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 20
总计 2,572
