简介
Why Fix a 2005 Laptop?
With a Pentium M 750 1.8 GHz and a 14" screen this makes a great "netbook" when running Linux Mint or Ubuntu.
Accessible Parts and Modules
This guide will explain how to remove the main logic board from the lower case and gain access to the second RAM slot, modem jack, wifi card, keyboard, LCD display connections, bezel switch module, cooling fan, speaker assembly, PCMCIA assembly, video, serial, parallel, power jack, ethernet jack, USB ports, touchpad assembly, and hinge knuckles.
你所需要的
Screw sizes are cross-point Phillips Head 0 and the slightly larger cross-point PH1
Each machine screw (meaning not pointy) overall length, from the top of the flat head to the last thread, is given to the nearest millimeter (mm).
All screws have a flat pan head, basically a low disc about 3mm dia.
I use a padded mat to protect the laptop cover. Anti-static is best, but even child's placemat will do
Remove the battery pack
Remove the optical drive
在这个步骤中使用的工具:Anti-Static Wrist Strap$7.95
Remove the cover for RAM slot B. It has a captive PH0 screw.
Use an anti-static wrist strap and gently remove the memory DIMM by spreading the two steel clips and tilting the DIMM towards you.
Remove the cover for the modem and the BIOS battery. It has a captive PH0 screw.
Remove 5 screws around the docking connector. They are PH0, black, 4mm
Remove 10 bronze 8mm case screws.
Not shown: you may also have to remove case screws 7,15,16, and hard drive assembly screws 19, 20 and 23. These were already missing on this laptop.
Using a spudger, remove the small access plate near the lower left corner, by tilting it into the battery compartment.
Look inside the corner where the access plate was and see the molded-in plastic clips which hold the bottom of the case to the keyboard bezel.
You may even begin using your spudger from the inside corner to begin unclipping the case bottom.
After working around the edges with the spudger, gently lift the bottom of the case, using the edge where all the ports are as the hinge.
A plastic ice cube tray stuck to the counter with poster putty (Blu-Tack) is handy for holding screws and parts. The putty keeps the tray from being knocked over. You may prefer to use a pill box with individual day of the week snap covers for more security.
Small plastic zip bags are handy for holding sets of screws and other small parts. They can be labeled with a permanent marker or stapled to a paper note describing where they came from.
After the lower case is disassembled, you can clean or replace modules or parts as needed.
You can also move on to disassemble the LCD portion of the laptop.
2等其他人完成本指南。
