你所需要的
Slide the release latch to unlock the battery cover [1].
Slide and lift the battery cover to remove it from the computer [2].
Slide the release latch to unlock the battery [1].
Lift and remove the battery from the computer [2].
Remove the screws that secure the base cover to the computer [1].
Slide and lift the base cover away from the computer [2].
Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
Pry the retention clips away from the primary memory until it pops up.
Lift the primary memory and remove it from the computer.
另外一个人完成了本指南。
