跳转到主内容
Dell Precision 7560 Solid-State Drive (SSD) Replacement
你所需要的
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 步骤 1 中的图像 1,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 步骤 1 中的图像 2,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: 步骤 1 中的图像 3,3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 1,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 2,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 3,3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 1,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 2,3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 3,3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 步骤 4 中的图像 1,2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 步骤 4 中的图像 2,2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 5 中的图像 1,2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: 步骤 5 中的图像 2,2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
结论
Hector
于02/14/23注册
249 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 47
总计 490
