跳转到主内容
Dell Precision 5520 Memory Module Replacement
你所需要的
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Precision 5520 Memory Module Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Memory Module Replacement, Battery: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: 步骤 3 中的图像 1,1
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
结论
Johnathan Hammond
于02/28/18注册
44,808 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,235
