跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide shows how to remove and replace the battery for the Dell Precision 5520 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
  1. Be sure to power off and unplug your device before you begin your repair. Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Disconnect the battery cable from the system board [1].
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
结论
3等其他人完成本指南。
Johnathan Hammond
于2018年02月28日注册
37,767 信誉积分
创作了408篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
32 名成员
创作了1,933篇指南
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - 回复
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 36
过去的30天: 141
总计 5,625
