跳转到主内容
加入维修社区 - 创建账户
Dell Precision 5510 RAM Replacement
你所需要的
  1. Dell Precision 5510 RAM Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 RAM Replacement: 步骤 2 中的图像 1,1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: 步骤 3 中的图像 1,2 Dell Precision 5510 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: 步骤 4 中的图像 1,1
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: 步骤 5 中的图像 1,1
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: 步骤 6 中的图像 1,1
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
结论
Cooper Zuranski
于03/31/22注册
109 声望
撰写一个指南
团队
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S2G1
4 名成员
创作了4篇指南
1指南评论
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - 回复 Share
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 790
