跳转到主内容
Dell Precision 5510 Keyboard Replacement
你所需要的
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: 步骤 3 中的图像 1,2 Dell Precision 5510 Keyboard Replacement, Fans: 步骤 3 中的图像 2,2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Precision 5510 Keyboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Precision 5510 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: 步骤 6 中的图像 1,2 Dell Precision 5510 Keyboard Replacement, Battery: 步骤 6 中的图像 2,2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Precision 5510 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: 步骤 8 中的图像 1,2 Dell Precision 5510 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: 步骤 12 中的图像 1,1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: 步骤 13 中的图像 1,1
    • Pull keyboard out and replace.
结论
Colin Hunter
于03/31/22注册
121 声望
撰写一个指南
团队
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S2G1
4 名成员
创作了4篇指南
一条评论
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 65
总计 1,789
