跳转到主内容
Dell Precision 5510 Fans Replacement
你所需要的
  1. Dell Precision 5510 Fans Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Fans Replacement: 步骤 2 中的图像 1,1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Fans Replacement, Fans: 步骤 3 中的图像 1,2 Dell Precision 5510 Fans Replacement, Fans: 步骤 3 中的图像 2,2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Fans Replacement: 步骤 4 中的图像 1,2 Dell Precision 5510 Fans Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Fans Replacement: 步骤 5 中的图像 1,2 Dell Precision 5510 Fans Replacement: 步骤 5 中的图像 2,2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
结论
Amelia Andrews
于03/31/22注册
97 声望
撰写一个指南
团队
IUPUI, Team 2-1, Harley Spring 2022 IUPUI, Team 2-1, Harley Spring 2022 的会员
IUPUI-HARLEY-S22S2G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 19
总计 468
