跳转到主内容
Dell Photo Printer 720 Encoder Strip Replacement
你所需要的
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: 步骤 1 中的图像 1,3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: 步骤 1 中的图像 2,3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: 步骤 1 中的图像 3,3
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: 步骤 2 中的图像 1,3 Dell Photo Printer 720 Encoder Strip Replacement: 步骤 2 中的图像 2,3 Dell Photo Printer 720 Encoder Strip Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: 步骤 3 中的图像 1,2 Dell Photo Printer 720 Encoder Strip Replacement: 步骤 3 中的图像 2,2
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: 步骤 4 中的图像 1,3 Dell Photo Printer 720 Encoder Strip Replacement: 步骤 4 中的图像 2,3 Dell Photo Printer 720 Encoder Strip Replacement: 步骤 4 中的图像 3,3
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
结论
另外一个人完成了本指南。
Megan Lawrence
于01/14/15注册
534 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 44
总计 818
