跳转到主内容
加入维修社区 - 创建账户
Dell Photo Printer 540 Power Switch Replacement
你所需要的
  1. Dell Photo Printer 540 Power Switch Replacement, Case: 步骤 1 中的图像 1,1
    • Rotate the photo printer so that the bottom of the case faces upward.
    询问修复机器人
    添加评论
  2. Dell Photo Printer 540 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
    询问修复机器人
    添加评论
  3. Dell Photo Printer 540 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
    询问修复机器人
    添加评论
  4. Dell Photo Printer 540 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
    询问修复机器人
    添加评论
  5. Dell Photo Printer 540 Power Switch Replacement: 步骤 5 中的图像 1,1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
    询问修复机器人
    添加评论
  6. Dell Photo Printer 540 Power Switch Replacement: 步骤 6 中的图像 1,2 Dell Photo Printer 540 Power Switch Replacement: 步骤 6 中的图像 2,2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
    询问修复机器人
    添加评论
  7. Dell Photo Printer 540 Power Switch Replacement, Cooling Fan: 步骤 7 中的图像 1,1
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
    询问修复机器人
    添加评论
  8. Dell Photo Printer 540 Power Switch Replacement: 步骤 8 中的图像 1,1
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
    询问修复机器人
    添加评论
  9. Dell Photo Printer 540 Power Switch Replacement: 步骤 9 中的图像 1,1
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
    询问修复机器人
    添加评论
  10. Dell Photo Printer 540 Power Switch Replacement, Mother Board: 步骤 10 中的图像 1,3 Dell Photo Printer 540 Power Switch Replacement, Mother Board: 步骤 10 中的图像 2,3 Dell Photo Printer 540 Power Switch Replacement, Mother Board: 步骤 10 中的图像 3,3
    • Locate the data ribbon that connects the LCD panel to the mother board.
    • Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
    • Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
    询问修复机器人
    添加评论
  11. Dell Photo Printer 540 Power Switch Replacement: 步骤 11 中的图像 1,3 Dell Photo Printer 540 Power Switch Replacement: 步骤 11 中的图像 2,3 Dell Photo Printer 540 Power Switch Replacement: 步骤 11 中的图像 3,3
    • Locate the clips with multi-colored wires that connect the motherboard to the printing unit.
    • Disconnect both of them by gently pulling them away from the motherboard.
    询问修复机器人
    添加评论
  12. Dell Photo Printer 540 Power Switch Replacement: 步骤 12 中的图像 1,3 Dell Photo Printer 540 Power Switch Replacement: 步骤 12 中的图像 2,3 Dell Photo Printer 540 Power Switch Replacement: 步骤 12 中的图像 3,3
    • Locate the white ribbon that connects the motherboard to the printing feed.
    • Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
    询问修复机器人
    添加评论
  13. Dell Photo Printer 540 Power Switch Replacement: 步骤 13 中的图像 1,2 Dell Photo Printer 540 Power Switch Replacement: 步骤 13 中的图像 2,2
    • The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
    • Locate the black data ribbon that connects the mother board to the printing motors.
    • Disconnect it from the logic board, by gently pulling the wire away from the mother board.
    询问修复机器人
    添加评论
  14. Dell Photo Printer 540 Power Switch Replacement: 步骤 14 中的图像 1,1
    • Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  15. Dell Photo Printer 540 Power Switch Replacement: 步骤 15 中的图像 1,1
    • Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
    询问修复机器人
    添加评论
  16. Dell Photo Printer 540 Power Switch Replacement, Removal of the Control Panel Motherboard: 步骤 16 中的图像 1,1
    • Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
    • Remove the front panel.
    • The dell top casing should now only have two sides.
    询问修复机器人
    添加评论
  17. Dell Photo Printer 540 Power Switch Replacement: 步骤 17 中的图像 1,2 Dell Photo Printer 540 Power Switch Replacement: 步骤 17 中的图像 2,2
    • Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing.
    • Use a Phillips Head #1 screw driver to remove the four highlighted screws.
    • NOTE: Make sure removal of front face plate is completed.
    询问修复机器人
    添加评论
  18. Dell Photo Printer 540 Power Switch Replacement: 步骤 18 中的图像 1,1
    • Gently lift the horizontal control panel motherboard and square power switch board.
    • Completely detach the motherboard from the face casing.
    • NOTE: Leave the power switch control attached to the main control panel motherboard.
    询问修复机器人
    添加评论
  19. Dell Photo Printer 540 Power Switch Replacement, Power Switch: 步骤 19 中的图像 1,2 Dell Photo Printer 540 Power Switch Replacement, Power Switch: 步骤 19 中的图像 2,2
    • Locate the multi-colored cable that connects the power switch to the control panel motherboard.
    • Detach the cable, power switch is now accessible.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
团队
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G7
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 39
总计 961
