跳转到主内容
Dell Photo Printer 540 Case Replacement
你所需要的
  1. Dell Photo Printer 540 Case Replacement, Case: 步骤 1 中的图像 1,1
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Case Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Case Replacement: 步骤 3 中的图像 1,1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Case Replacement: 步骤 4 中的图像 1,1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Case Replacement: 步骤 5 中的图像 1,1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Case Replacement: 步骤 6 中的图像 1,2 Dell Photo Printer 540 Case Replacement: 步骤 6 中的图像 2,2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
结论
Jonathan Mintz
于04/04/12注册
11 声望
创作了3篇指南
团队
Cal Poly, Team 14-7, Forte Spring 2012 Cal Poly, Team 14-7, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G7
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 599
