当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
Pull the upper fan out of the computer.
取消:我没有完成这个指南。
7等其他人完成本指南。
与5其他贡献者
于10/04/10注册
841 声望
创作了7篇指南
徽章: 11
+ 8更多徽章
CPSU-MANESS-F10S22G4
4 名成员
创作了26篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 5,250
