跳转到主内容
Dell Optiplex SX280 Upper Fan Replacement
你所需要的
  1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Upper Fan Replacement: 步骤 2 中的图像 1,2 Dell Optiplex SX280 Upper Fan Replacement: 步骤 2 中的图像 2,2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Upper Fan Replacement: 步骤 3 中的图像 1,2 Dell Optiplex SX280 Upper Fan Replacement: 步骤 3 中的图像 2,2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: 步骤 4 中的图像 1,2 Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: 步骤 4 中的图像 2,2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Upper Fan Replacement: 步骤 5 中的图像 1,2 Dell Optiplex SX280 Upper Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Dell Optiplex SX280 Upper Fan Replacement: 步骤 6 中的图像 1,2 Dell Optiplex SX280 Upper Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
  7. Dell Optiplex SX280 Upper Fan Replacement: 步骤 7 中的图像 1,1
    • Pull the upper fan out of the computer.
结论
7等其他人完成本指南。
Tom
于10/04/10注册
841 声望
创作了7篇指南
团队
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G4
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 5,250
