跳转到主内容
Dell Optiplex SX280 RAM Replacement
  1. Dell Optiplex SX280 RAM Replacement, Panel Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 RAM Replacement: 步骤 2 中的图像 1,2 Dell Optiplex SX280 RAM Replacement: 步骤 2 中的图像 2,2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 RAM Replacement: 步骤 3 中的图像 1,2 Dell Optiplex SX280 RAM Replacement: 步骤 3 中的图像 2,2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  5. Dell Optiplex SX280 RAM Replacement: 步骤 5 中的图像 1,2 Dell Optiplex SX280 RAM Replacement: 步骤 5 中的图像 2,2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
结论
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
8等其他人完成本指南。
Wyatt
于10/06/10注册
775 声望
创作了6篇指南
团队
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G4
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 5,497
