简介
Remove the Motherboard from the computer.
配件
无需配件。
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place. Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Press down on the release tab above the heat sink. Press down on the release tab above the heat sink.
    • Press down on the release tab above the heat sink.
  6. Pull the heat sink out of the computer while pressing on the release tab. When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
  7. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  8. Remove the rubber grommets from the base of the fan. A spudger may be useful. Remove the rubber grommets from the base of the fan. A spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  9. Press on the blue release tab and pull the upper fan out of the computer. Press on the blue release tab and pull the upper fan out of the computer.
    • Press on the blue release tab and pull the upper fan out of the computer.
  10. Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires. Make sure to press on the release tab while removing the power connector.
    • Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Make sure to press on the release tab while removing the power connector.
  11. Remove the rubber grommets from the base of the fan. A spudger may be useful. Remove the rubber grommets from the base of the fan. A spudger may be useful.
  12. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  13. Press on the blue release tab and remove the fan. Press on the blue release tab and remove the fan.
    • Press on the blue release tab and remove the fan.
  14. The RAM are the two green cards in the corner of the computer.
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  15. Push down both white clips with your thumbs until you hear a click. The RAM cards can now be removed.
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
  16. Unplug the blue cable that connects the hard drive to the motherboard. Unplug the blue cable that connects the hard drive to the motherboard.
    • Unplug the blue cable that connects the hard drive to the motherboard.
  17. Unplug the power supply, distinguished by its red and yellow wires.
    • Unplug the power supply, distinguished by its red and yellow wires.
  18. Squeeze the release tabs on either side of the hard drive.
    • Squeeze the release tabs on either side of the hard drive.
    • Then slide the hard drive out of the computer while squeezing the tabs.
  19. Unplug the cable that connects the hard drive to the Motherboard.
    • Unplug the cable that connects the hard drive to the Motherboard.
  20. Press on the release tab and remove the motherboard speaker which is attached to the side of the tower. Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
    • Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
  21. Unplug the power cable attached to the motherboard speaker.
    • Unplug the power cable attached to the motherboard speaker.
    • Make sure to press on the release tab while removing the power cable.
  22. Remove four screws located at the back of the computer tower. Remove four screws located at the back of the computer tower.
    • Remove four screws located at the back of the computer tower.
  23. Carefully detach the motherboard from the computer case.
    • Carefully detach the motherboard from the computer case.
  24. Lift the motherboard from the rest of the computer case.
    • Lift the motherboard from the rest of the computer case.
  25. Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
    • Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
    • Make sure to press the release tab while removing the cable.
  26. Unplug the cable that powers the emergency shut off, distinguished by its red wires. Make sure to press on the release tab while removing the emergency shut off.
    • Unplug the cable that powers the emergency shut off, distinguished by its red wires.
    • Make sure to press on the release tab while removing the emergency shut off.
  27. Remove two screws from the Hard Drive Stand. Remove two screws from the Hard Drive Stand.
    • Remove two screws from the Hard Drive Stand.
  28. Slide the Hard Drive Stand to left side. Remove the stand from the rest of the rear panel.
    • Slide the Hard Drive Stand to left side.
    • Remove the stand from the rest of the rear panel.
  29. Remove the studs that support the Hard Drive Stand from the motherboard. The studs can be removed by hand.
    • Remove the studs that support the Hard Drive Stand from the motherboard.
    • The studs can be removed by hand.
  30. Remove the four screws located on heat sink stand. The heat sink stand can now be lifted from the motherboard. The heat sink stand can now be lifted from the motherboard.
    • Remove the four screws located on heat sink stand.
    • The heat sink stand can now be lifted from the motherboard.
  31. Remove the four screws holding the motherboard to the rear computer panel. Remove the four screws holding the motherboard to the rear computer panel.
    • Remove the four screws holding the motherboard to the rear computer panel.
  32. The motherboard can now be removed from the remaining panel. The motherboard can now be removed from the remaining panel.
    • The motherboard can now be removed from the remaining panel.
结论
10等其他人完成本指南。
Tom
于2010年10月04日注册
799 信誉积分
创作了7篇指南
团队
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G4
4 名成员
创作了13篇指南
Good job. Thanks for sharing, friend.
Angel Peguero - 回复
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
purchases - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 14
总计 18,220
