跳转到主内容
Dell Optiplex SX280 Battery Replacement
你所需要的
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: 步骤 2 中的图像 1,2 Dell Optiplex SX280 Battery Replacement: 步骤 2 中的图像 2,2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: 步骤 3 中的图像 1,2 Dell Optiplex SX280 Battery Replacement: 步骤 3 中的图像 2,2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: 步骤 4 中的图像 1,2 Dell Optiplex SX280 Battery Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: 步骤 5 中的图像 1,2 Dell Optiplex SX280 Battery Replacement: 步骤 5 中的图像 2,2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: 步骤 6 中的图像 1,1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: 步骤 7 中的图像 1,2 Dell Optiplex SX280 Battery Replacement: 步骤 7 中的图像 2,2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: 步骤 8 中的图像 1,1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: 步骤 9 中的图像 1,1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: 步骤 10 中的图像 1,3 Dell Optiplex SX280 Battery Replacement: 步骤 10 中的图像 2,3 Dell Optiplex SX280 Battery Replacement: 步骤 10 中的图像 3,3
    • Upon replacement, simply push the battery into the motherboard.
结论
10等其他人完成本指南。
Tom
于10/04/10注册
841 声望
创作了7篇指南
团队
Cal Poly, Team 22-4, Maness Fall 2010 Cal Poly, Team 22-4, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G4
4 名成员
创作了26篇指南
一条评论
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 11,764
