跳转到主内容
Dell Optiplex GX620 Power Supply Replacement
你所需要的
  1. Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Power Supply Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 Power Supply Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Power Supply Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 步骤 4 中的图像 1,3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 步骤 4 中的图像 2,3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: 步骤 4 中的图像 3,3
    • Gently disconnect the power cables from the motherboard and drives.
  5. Dell Optiplex GX620 Power Supply Replacement, Remove the screws: 步骤 5 中的图像 1,1
    • Remove the four screws that attach the power supply on the back of the chassis.
    • Do not remove any screws that are not highlighted in red.
  6. Dell Optiplex GX620 Power Supply Replacement, Press the release button: 步骤 6 中的图像 1,1
    • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  7. Dell Optiplex GX620 Power Supply Replacement, Remove the power supply: 步骤 7 中的图像 1,1
    • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
结论
10等其他人完成本指南。
Kristina
于09/03/14注册
204 声望
创作了7篇指南
团队
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G1
10 名成员
创作了15篇指南
3条评论
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - 回复
i replaced that but not repair this
Muhammad Qasim - 回复
At post Madasanal TQ disk bijapur
sidaray - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 21
总计 7,092
