跳转到主内容
Dell Optiplex GX620 Network Adapter Replacement
  1. Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Network Adapter Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 Network Adapter Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Network Adapter Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: 步骤 4 中的图像 1,2 Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: 步骤 4 中的图像 2,2
    • Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
  5. Dell Optiplex GX620 Network Adapter Replacement, Removing the Network Adapter: 步骤 5 中的图像 1,1
    • With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
结论
2等其他人完成本指南。
Kristina
于09/03/14注册
198 声望
创作了7篇指南
团队
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G1
10 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,185
