跳转到主内容
Dell Optiplex GX620 Front panel Replacement
你所需要的
  1. Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Front panel Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Front panel Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 步骤 4 中的图像 1,3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 步骤 4 中的图像 2,3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: 步骤 4 中的图像 3,3
    • Remove the SATA power and data cables.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 步骤 5 中的图像 1,3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 步骤 5 中的图像 2,3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: 步骤 5 中的图像 3,3
    • Unplug the power and data cables.
  6. Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: 步骤 6 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: 步骤 6 中的图像 2,2
    • Unplug the fan.
  7. Dell Optiplex GX620 Front panel Replacement: 步骤 7 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement: 步骤 7 中的图像 2,2
    • Remove the two Phillips #2 screws.
  8. Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 步骤 8 中的图像 1,3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 步骤 8 中的图像 2,3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: 步骤 8 中的图像 3,3
    • Pull the heat sink up.
  9. Dell Optiplex GX620 Front panel Replacement: 步骤 9 中的图像 1,3 Dell Optiplex GX620 Front panel Replacement: 步骤 9 中的图像 2,3 Dell Optiplex GX620 Front panel Replacement: 步骤 9 中的图像 3,3
    • Pull the two tabs and pull it out.
    • This needs a lot of force to take it off.
  10. Dell Optiplex GX620 Front panel Replacement, Remove front panel: 步骤 10 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement, Remove front panel: 步骤 10 中的图像 2,2
    • Remove the one Phillips #2.
    • Remove the Data cable.
    • Taking this cable off will brake some of the plastic thats locking it in. But you can still plug the cable back in.
  11. Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: 步骤 11 中的图像 1,2 Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: 步骤 11 中的图像 2,2
    • Remove the one Phillips #2 screw.
    • Now you can replace it with a new one.
结论
另外一个人完成了本指南。
Padraic Hoselton
于08/22/17注册
4,204 声望
创作了12篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,544
