跳转到主内容
Dell Optiplex GX620 Floppy Drive Replacement
你所需要的
  1. Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Floppy Drive Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 Floppy Drive Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Floppy Drive Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Floppy Drive Replacement, Remove the drive panel: 步骤 4 中的图像 1,1
    • Slide the blue latch downward until the panel can be removed from it's hinges.
  5. Dell Optiplex GX620 Floppy Drive Replacement, Disconnect the cables: 步骤 5 中的图像 1,1
    • Gently remove the floppy-drive and power cables from the back of the floppy drive.
  6. Dell Optiplex GX620 Floppy Drive Replacement, Remove the screws: 步骤 6 中的图像 1,1
    • With a Phillips #1 screwdriver, remove the screws connecting the floppy drive to the drive bay. Set the screws aside in a location where you may use them at a later time.
  7. Dell Optiplex GX620 Floppy Drive Replacement, Remove the floppy drive: 步骤 7 中的图像 1,1
    • To remove the unconnected floppy drive from the drive bay, slide the drive towards the front of the computer.
结论
另外一个人完成了本指南。
Kristina
于09/03/14注册
204 声望
创作了7篇指南
团队
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G1
10 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 1,534
