跳转到主内容
Dell Optiplex GX620 CPU Replacement
你所需要的
  1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CPU Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 CPU Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 步骤 4 中的图像 1,3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 步骤 4 中的图像 2,3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: 步骤 4 中的图像 3,3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 步骤 5 中的图像 1,3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 步骤 5 中的图像 2,3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: 步骤 5 中的图像 3,3
    • Unplug the power cable
    • Unplug the data cable
  6. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 步骤 6 中的图像 1,2 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: 步骤 6 中的图像 2,2
    • Unplug the fan that is on the motherboard.
  7. Dell Optiplex GX620 CPU Replacement: 步骤 7 中的图像 1,2 Dell Optiplex GX620 CPU Replacement: 步骤 7 中的图像 2,2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
  8. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 步骤 8 中的图像 1,3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 步骤 8 中的图像 2,3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: 步骤 8 中的图像 3,3
    • Lift the heat sink.
  9. Dell Optiplex GX620 CPU Replacement, CPU removal.: 步骤 9 中的图像 1,3 Dell Optiplex GX620 CPU Replacement, CPU removal.: 步骤 9 中的图像 2,3 Dell Optiplex GX620 CPU Replacement, CPU removal.: 步骤 9 中的图像 3,3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
结论
3等其他人完成本指南。
Padraic Hoselton
于08/22/17注册
4,180 声望
创作了12篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,506篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 2,154
