跳转到主内容
加入维修社区 - 创建账户
Dell Optiplex GX620 CMOS Battery Replacement
你所需要的
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 1,2 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 步骤 1 中的图像 2,2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: 步骤 2 中的图像 1,2 Dell Optiplex GX620 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: 步骤 3 中的图像 1,1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: 步骤 4 中的图像 1,1
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
结论
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
9等其他人完成本指南。
Kristina
于09/03/14注册
213 声望
创作了7篇指南
团队
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G1
10 名成员
创作了15篇指南
2指南评论
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - 回复 分享
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 133
总计 17,240
