跳转到主内容
Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement
  1. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 步骤 3 中的图像 1,1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Ground yourself to avoid static from damaging any components. Either use a wrist strap and antistatic mat, or touch the metal computer case every few minutes.
    • Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
  5. Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Optiplex 745 Ultra Small Form Factor Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Locate the blue tabs shown on the left and right of the hard disk drive
    • Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
结论
donnavon
于09/02/14注册
707 声望
创作了7篇指南
团队
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S1G1
11 名成员
创作了14篇指南
一条评论
I need of one this..+966551432137 WhatsApp
Luke Zoie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,559
