跳转到主内容
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
你所需要的
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 2 中的图像 1,1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 3 中的图像 1,1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 步骤 4 中的图像 1,2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: 步骤 4 中的图像 2,2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 5 中的图像 1,3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 5 中的图像 2,3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 5 中的图像 3,3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 步骤 6 中的图像 1,2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: 步骤 6 中的图像 2,2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 7 中的图像 1,2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 7 中的图像 2,2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: 步骤 8 中的图像 1,1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
结论
另外一个人完成了本指南。
donnavon
于09/02/14注册
707 声望
创作了7篇指南
团队
Pasco Hernando, Team 1-1, Prince Fall 2014 Pasco Hernando, Team 1-1, Prince Fall 2014 的会员
PHSC-PRINCE-F14S1G1
11 名成员
创作了14篇指南
一条评论
What Cpu does it use?
Jazelle Estrada - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 2,165
