跳转到主内容
Dell Optiplex 745 Small Form Factor Processor Replacement
你所需要的
  1. Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: 步骤 1 中的图像 1,2 Dell Optiplex 745 Small Form Factor Processor Replacement, Opening the case: 步骤 1 中的图像 2,2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 2 中的图像 1,2 Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 2 中的图像 2,2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Processor Replacement, Processor: 步骤 3 中的图像 1,1
    • The processor is located inside the heat sink (indicated by the marker).
  4. Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 4 中的图像 1,3 Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 4 中的图像 2,3 Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 4 中的图像 3,3
    • Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
    • If the processor is glued on to the heat sink, gently scrape off the glue and detach it from the device.
  5. Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 5 中的图像 1,3 Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 5 中的图像 2,3 Dell Optiplex 745 Small Form Factor Processor Replacement: 步骤 5 中的图像 3,3
    • Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
    • Remove the processor from its casing.
结论
3等其他人完成本指南。
Abdullah Khan
于10/03/17注册
181 声望
撰写一个指南
团队
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G5
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 27
总计 1,214
