跳转到主内容
Dell Optiplex 745 Small Form Factor Power Supply Replacement
你所需要的
  1. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: 步骤 1 中的图像 1,2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Opening the case: 步骤 1 中的图像 2,2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Power Supply Replacement: 步骤 2 中的图像 1,2 Dell Optiplex 745 Small Form Factor Power Supply Replacement: 步骤 2 中的图像 2,2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: 步骤 3 中的图像 1,2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the Power Supply from the Case: 步骤 3 中的图像 2,2
    • Identify the power supply.
    • Remove the two 9.5 mm Phillips screws on the outside of the case.
  4. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: 步骤 4 中的图像 1,2 Dell Optiplex 745 Small Form Factor Power Supply Replacement, Disconnect the power supply cables: 步骤 4 中的图像 2,2
    • Grab the plastic casing and pull out the bundle of cables from the side of the power supply unit.
  5. Dell Optiplex 745 Small Form Factor Power Supply Replacement, Remove the power supply: 步骤 5 中的图像 1,1
    • Push the power supply from the back and lift from the front.
    • Lift the power supply out of the case.
结论
16等其他人完成本指南。
Samantha Hsu
于09/29/14注册
416 声望
撰写一个指南
团队
Cal Poly, Team 13-10, Forte Fall 2014 Cal Poly, Team 13-10, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G10
6 名成员
创作了12篇指南
一条评论
good, but that's not the SFF model.
99mmarriott99 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 6,619
