跳转到主内容
Dell Optiplex 745 Small Form Factor Audio Components Replacement
你所需要的
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: 步骤 1 中的图像 1,2 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: 步骤 1 中的图像 2,2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 步骤 2 中的图像 1,2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: 步骤 2 中的图像 2,2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: 步骤 3 中的图像 1,1
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: 步骤 5 中的图像 1,2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: 步骤 5 中的图像 2,2
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
结论
另外一个人完成了本指南。
Jeremy Nicholas
于10/09/17注册
228 声望
创作了2篇指南
团队
USF Tampa, Team S5-G5, Walkup Fall 2017 USF Tampa, Team S5-G5, Walkup Fall 2017 的会员
USFT-WALKUP-F17S5G5
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,176
