跳转到主内容
Dell Optiplex 745 Motherboard Replacement
你所需要的
  1. Dell Optiplex 745 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Orientate the computer so the case lock is on the left corner, like so.
    • Pull the tab that locks the casing in place.
    • While the tab is pulled, lift the casing off the computer.
  2. Dell Optiplex 745 Motherboard Replacement: 步骤 2 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 2 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Lift the three tabs locking the face into place. (The plastic prying tool makes this easier.)
    • Pull the plastic face off of the computer.
  3. Dell Optiplex 745 Motherboard Replacement: 步骤 3 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 3 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pinch the two tabs locking the fan mount (annotated in a blue square).
    • Pull the mount up and out of the computer.
  4. Dell Optiplex 745 Motherboard Replacement: 步骤 4 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 4 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pull the orange connector out of the CD drive (annotated in an orange square).
    • Pull out the smaller connector (annotated in a black square). Tweezers make it easier but aren't required.
  5. Dell Optiplex 745 Motherboard Replacement: 步骤 5 中的图像 1,2 Dell Optiplex 745 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull the CD drive lock (annotated in blue) straight up.
    • While holding the lock up, pull out the CD drive.
  6. Dell Optiplex 745 Motherboard Replacement: 步骤 6 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 6 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Unscrew the two screws (annotated with red circles) holding the GPU heatsync in place.
    • Swing it open then pull it straight up.
  7. Dell Optiplex 745 Motherboard Replacement: 步骤 7 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 7 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Unscrew the two screws (annotated with a red circle).
    • Pull out the hinge for the GPU heatsync.
  8. Dell Optiplex 745 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull out the yellow and black connector that is connected to the Motherboard.
  9. Dell Optiplex 745 Motherboard Replacement: 步骤 9 中的图像 1,2 Dell Optiplex 745 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull out the large white power connector that is connected to the Motherboard.
    • Use the plastic prying tool to pull it up.
    • Alternate sides when prying until it comes loose.
  10. Dell Optiplex 745 Motherboard Replacement: 步骤 10 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 10 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Unscrew the three screws (annotated in red).
    • Slide out the AC adapter.
    • If all the cables are detached, it should slide right out. If not, detach the remaining cables.
  11. Dell Optiplex 745 Motherboard Replacement: 步骤 11 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 11 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Remove the blue wire connected to the Motherboard.
    • Remove the orange wire connected to the Motherboard.
    • Remove the wide grey connector from the Motherboard.
    • Use the yellow handle to pull it up.
  12. Dell Optiplex 745 Motherboard Replacement: 步骤 12 中的图像 1,2 Dell Optiplex 745 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the last wire connected to the Motherboard.
    • Remove the grey wire connected to the fan.
  13. Dell Optiplex 745 Motherboard Replacement: 步骤 13 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 13 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Unscrew the two screws holding the Motherboard down (annotated with the red circles).
  14. Dell Optiplex 745 Motherboard Replacement: 步骤 14 中的图像 1,2 Dell Optiplex 745 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Carefully lift the right side of the Motherboard.
    • After lifting it above the fan, pull it to the right to remove the Motherboard.
  15. Dell Optiplex 745 Motherboard Replacement: 步骤 15 中的图像 1,3 Dell Optiplex 745 Motherboard Replacement: 步骤 15 中的图像 2,3 Dell Optiplex 745 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Starting with the left side, insert the new Motherboard.
    • Once the ports are lined up, set down the right side of the Motherboard.
    • Then screw it back in and reassemble.
结论
4等其他人完成本指南。
一条评论
Thank you and your contributors for providing this guide. I did not replace motherboard but three 2200 u capacitors on it. The thing works again!
Antti Huhtala - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 42
总计 4,546
