跳转到主内容
Dell OptiPlex GX260 Power Supply Replacement
你所需要的
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: 步骤 1 中的图像 1,2 Dell OptiPlex GX260 Power Supply Replacement, Case: 步骤 1 中的图像 2,2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: 步骤 2 中的图像 1,1
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: 步骤 3 中的图像 1,1
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: 步骤 4 中的图像 1,1
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
结论
6等其他人完成本指南。
Kevin Schapansky
于10/05/10注册
1,466 声望
创作了9篇指南
团队
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G48
4 名成员
创作了27篇指南
一条评论
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 13,210
