跳转到主内容
Dell OptiPlex GX260 Optical Drive Replacement
你所需要的
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: 步骤 1 中的图像 1,2 Dell OptiPlex GX260 Optical Drive Replacement, Case: 步骤 1 中的图像 2,2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 1,3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 2,3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 3,3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
结论
5等其他人完成本指南。
Kevin Schapansky
于10/05/10注册
1,466 声望
创作了9篇指南
团队
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G48
4 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 8,867
