跳转到主内容
Dell OptiPlex GX260 Main Fan Replacement
你所需要的
  1. Dell OptiPlex GX260 Main Fan Replacement, Case: 步骤 1 中的图像 1,2 Dell OptiPlex GX260 Main Fan Replacement, Case: 步骤 1 中的图像 2,2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Main Fan Replacement, Main Fan: 步骤 2 中的图像 1,2 Dell OptiPlex GX260 Main Fan Replacement, Main Fan: 步骤 2 中的图像 2,2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Main Fan Replacement: 步骤 3 中的图像 1,3 Dell OptiPlex GX260 Main Fan Replacement: 步骤 3 中的图像 2,3 Dell OptiPlex GX260 Main Fan Replacement: 步骤 3 中的图像 3,3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
结论
7等其他人完成本指南。
Kevin Schapansky
于10/05/10注册
1,457 声望
创作了9篇指南
团队
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G48
4 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 7,988
