跳转到主内容
Dell OptiPlex GX260 Hard Drive Replacement
你所需要的
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: 步骤 1 中的图像 1,2 Dell OptiPlex GX260 Hard Drive Replacement, Case: 步骤 1 中的图像 2,2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 3,3
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
结论
8等其他人完成本指南。
Kevin Schapansky
于10/05/10注册
1,466 声望
创作了9篇指南
团队
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G48
4 名成员
创作了27篇指南
一条评论
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 18,820
