跳转到主内容
Dell OptiPlex FX170 Memory Board Replacement
你所需要的
  1. Dell OptiPlex FX170 Memory Board Replacement, Case: 步骤 1 中的图像 1,1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Memory Board Replacement: 步骤 2 中的图像 1,2 Dell OptiPlex FX170 Memory Board Replacement: 步骤 2 中的图像 2,2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Memory Board Replacement: 步骤 3 中的图像 1,3 Dell OptiPlex FX170 Memory Board Replacement: 步骤 3 中的图像 2,3 Dell OptiPlex FX170 Memory Board Replacement: 步骤 3 中的图像 3,3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Memory Board Replacement: 步骤 4 中的图像 1,2 Dell OptiPlex FX170 Memory Board Replacement: 步骤 4 中的图像 2,2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: 步骤 5 中的图像 1,1
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 1,430
