简介
You should be familiar with the basics of taking apart a computer take apart, specifically in terms of preventing further damage due to electro-static discharge (ESD).
你所需要的
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
To remove the battery, pull up on the connector that is plugged into the motherboard.
即将完成!
结论
