简介
Are you experiencing issues with your computer overheating, generating loud noises, or crashing frequently? If yes, you may have a problem with your CPU fan.
The CPU cooling fan plays a crucial role in cooling down your computer, preventing it from overheating and slowing down. Replacing your PC's old fan will not only help prolong your CPU's lifespan but also the life of your Dell OptiPlex 9010.
Follow this guide if you need to replace the CPU fan of your Dell OptiPlex 9010.
Before you begin, turn off your computer and unplug from the outlet.
你所需要的
Place the PC on a flat surface.
Turn the PC over so that the panel side faces upward.
Unscrew the 1.2 mm screw using a Phillips #1 screwdriver by turning it counterclockwise (left)
Place screws back in the holes
Tighten screws using the Phillips #1 screwdriver by turning it clockwise (right).
You have successfully replaced the CPU Fan of your Dell Optiplex 9010!
另外一个人完成了本指南。
