跳转到主内容
Dell Latitude X300 RAM Replacement
你所需要的
  1. Dell Latitude X300 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Dell Latitude X300 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Dell Latitude X300 RAM Replacement: 步骤 2 中的图像 1,1
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Dell Latitude X300 RAM Replacement: 步骤 3 中的图像 1,1
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  4. Dell Latitude X300 RAM Replacement: 步骤 4 中的图像 1,1
    • Insert the new memory at 45 degree angle.
  5. Dell Latitude X300 RAM Replacement: 步骤 5 中的图像 1,1
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
结论
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
于01/20/12注册
23 声望
创作了2篇指南
团队
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G20
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,235
