跳转到主内容
Dell Latitude X300 Latch Replacement
你所需要的
  1. Dell Latitude X300 Latch Replacement, Latch: 步骤 1 中的图像 1,1
    • Make sure the power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Latch Replacement: 步骤 2 中的图像 1,2 Dell Latitude X300 Latch Replacement: 步骤 2 中的图像 2,2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Latch Replacement: 步骤 3 中的图像 1,1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so use extreme care.
  4. Dell Latitude X300 Latch Replacement: 步骤 4 中的图像 1,1
    • Remove the screws holding the latch in place.
    • Replace the old latch with the new one
结论
2等其他人完成本指南。
Jacob
于03/12/14注册
9 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S6G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 342
