跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Dell Latitude X300 Keyboard Replacement
你所需要的
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  2. Dell Latitude X300 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Latitude X300 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: 步骤 3 中的图像 1,1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the flexible ribbon from ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
结论
Jacob Egorov
于01/20/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G20
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,230
