跳转到主内容
Dell Latitude X300 Hard Drive Replacement
你所需要的
  1. Dell Latitude X300 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Hard Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Latitude X300 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Hard Drive Replacement, Palm Rest/Track Pad: 步骤 8 中的图像 1,1
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
  12. Dell Latitude X300 Hard Drive Replacement, Hard Drive: 步骤 12 中的图像 1,1
    • Remove the 4 #00 5 mm screws holding the hard drive to the case.
  13. Dell Latitude X300 Hard Drive Replacement: 步骤 13 中的图像 1,1
    • Carefully pull up on the hard molded plastic portion of the ribbon to detach it from the computer.
  14. Dell Latitude X300 Hard Drive Replacement: 步骤 14 中的图像 1,1
    • Remove the hard drive from the laptop.
结论
2等其他人完成本指南。
Taylor Bateman
于01/20/12注册
93 声望
创作了2篇指南
团队
Cal Poly, Team 11-20, Maness Winter 2012 Cal Poly, Team 11-20, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G20
4 名成员
创作了7篇指南
一条评论
I have to know cause its long time ago i was using this pc,
and i really forgot my HD password and dont know where to find it,sorry
Bernard Vandenberghe - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 9,757
