当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before removing the battery from the laptop, make sure the power is off.
Push both battery locking clips outward at the same time.
Carefully turn the laptop over and open the screen all the way.
Locate the slot to remove the keyboard in the lower left hand corner.
Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
Lift up on the small ZIF connector and remove the ribbon.
If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
