简介
If the screen on your Dell latitude ST is displaying as black you should try rebooting the system. If this does not fix the screen you may want to replace the screen. This guide shows you how to safely replace your Dell Latitude ST screen.
你所需要的
Pull up on the copper antenna tape to loosen it from the base.
Unscrew the seven 6mm Phillips #0 screws from the base.
结论
