跳转到主内容
Dell Latitude E7470 Network Card Replacement
你所需要的
  1. Dell Latitude E7470 Network Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Network Card Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Network Card Replacement: 步骤 3 中的图像 1,2 Dell Latitude E7470 Network Card Replacement: 步骤 3 中的图像 2,2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Network Card Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Network Card Replacement, Network Card: 步骤 5 中的图像 1,2 Dell Latitude E7470 Network Card Replacement, Network Card: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    购买
    • Use a halberd spudger and your fingers to detach two wires from the Wi-Fi card.
  6. Dell Latitude E7470 Network Card Replacement: 步骤 6 中的图像 1,1
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  7. Dell Latitude E7470 Network Card Replacement: 步骤 7 中的图像 1,1
    • Use an iFixit opening tool and your fingers to pull the Wi-Fi card out of its socket.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 671
