跳转到主内容
Dell Latitude E7470 Motherboard Replacement
你所需要的
  1. Dell Latitude E7470 Motherboard Replacement, RAM: 步骤 1 中的图像 1,2 Dell Latitude E7470 Motherboard Replacement, RAM: 步骤 1 中的图像 2,2
    • Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
    • Remove the RAM from the device.
    • Repeat this for second RAM stick
  2. Dell Latitude E7470 Motherboard Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Motherboard Replacement: 步骤 3 中的图像 1,2 Dell Latitude E7470 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: 步骤 5 中的图像 1,2 Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: 步骤 5 中的图像 2,2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
  7. Dell Latitude E7470 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Dell Latitude E7470 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Dell Latitude E7470 Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Remove all the screws using a Phillips #0 screwdriver.
    • Disconnect all of the cables from the motherboard.
  8. Dell Latitude E7470 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard from the laptop.
结论
2等其他人完成本指南。
一条评论
Good overall, the motherboard screw picture shows too many screws. Also, might need a picture of removing the two side screws for the port cover, and that there are two screws next to the expansion port, under the port cover.
Charles Coburn - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 34
总计 3,604
