跳转到主内容
Dell Latitude E7470 Fan and Heatsink Replacement
你所需要的
  1. 注意:步骤 1 源自标记为进行中的 指南
    Dell Latitude E7470 Fan and Heatsink Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Fan and Heatsink Replacement, Battery: 步骤 2 中的图像 1,1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Fan and Heatsink Replacement: 步骤 3 中的图像 1,2 Dell Latitude E7470 Fan and Heatsink Replacement: 步骤 3 中的图像 2,2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Fan and Heatsink Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: 步骤 5 中的图像 1,2 Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: 步骤 5 中的图像 2,2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Fan and Heatsink Replacement: 步骤 6 中的图像 1,1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 62
总计 2,601
