本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide introduces how to remove the battery from Dell Latitude E7470. The laptop comes with different battery configurations. While this guide shows how to replace a standard capacity battery, the procedure is similar when replacing the extended capacity battery.
你所需要的
步骤 1 Back Cover
注意:步骤 1 源自标记为进行中的 指南。
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
9等其他人完成本指南。
