跳转到主内容
Dell Latitude E7440 Keyboard Replacement
你所需要的
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: 步骤 2 中的图像 1,3 Dell Latitude E7440 Keyboard Replacement: 步骤 2 中的图像 2,3 Dell Latitude E7440 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: 步骤 3 中的图像 1,3 Dell Latitude E7440 Keyboard Replacement: 步骤 3 中的图像 2,3 Dell Latitude E7440 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Dell Latitude E7440 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Latitude E7440 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: 步骤 6 中的图像 1,3 Dell Latitude E7440 Keyboard Replacement: 步骤 6 中的图像 2,3 Dell Latitude E7440 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
结论
6等其他人完成本指南。
Sheetal Prasanna
于11/06/19注册
649 声望
创作了3篇指南
团队
IUPUI, Team S1-G1, Stella Fall 2019 IUPUI, Team S1-G1, Stella Fall 2019 的会员
IUPUI-STELLA-F19S1G1
4 名成员
创作了3篇指南
2条评论
for step three i would add “ the cables to be removed are under a type of flap/cover”. I don’t know if we have to be specific on what tools we used. If we do have to be specific than we will just add them. Other than that great work!
Oscar Aca - 回复
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
Jamie O'Hare - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 34
总计 5,011
