跳转到主内容
Dell Latitude E7440 CMOS Battery Replacement
你所需要的
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: 步骤 1 中的图像 1,1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 步骤 2 中的图像 1,3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 步骤 2 中的图像 2,3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: 步骤 2 中的图像 3,3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 1,2 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 2,2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: 步骤 5 中的图像 1,2 Dell Latitude E7440 CMOS Battery Replacement: 步骤 5 中的图像 2,2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: 步骤 6 中的图像 1,3 Dell Latitude E7440 CMOS Battery Replacement: 步骤 6 中的图像 2,3 Dell Latitude E7440 CMOS Battery Replacement: 步骤 6 中的图像 3,3
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: 步骤 7 中的图像 1,1
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
结论
6等其他人完成本指南。
Akash Kedia
于01/24/19注册
1,397 声望
创作了5篇指南
团队
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 的会员
CPSU-WHITE-W19S2G5
4 名成员
创作了5篇指南
2条评论
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - 回复
@jess13j, battery is a CR2032 coin cell.
senzog - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 102
总计 13,312
